djkutasi
Thanks for your advise, but i wanted to try this X500 because this would be the "budget "upgrade compare to my Sony VW50ES.
Originally i wanted to have a 350 or 500ES, but those projectors are still quite expensive. Buying a new JVC model would cost even more i think.
Anyway, the brightness is not my priority, but don't really want to have a darker image, than my Sony has at the moment. I think the JVC claimed to 1300 lumens, and my Sony is 1700. Tho' i know these are just numbers.
So what about a Sony VW50ES vs JVC DLA X500?
Does it worth to change?
The X500 is significantly brighter than the X3, but if brightness is your priority, you may want to wait for the X5000, which launches next month. This, and the other models in the new range use a new 265W lamp and are significantly brighter than even the X500.
