Simonofthepiemans
Hi all
I'm looking at buying buying either of the above two systems and am erring towards the LS50's, although I think the question stands for either model.
In terms of Bluetooth streaming what are the limitations. I know that it supports Tidal, Spotify connect, and Apple but if I were to play other media from either my laptop or phone would I have to connect with cables or simply select the speakers as a connected output?
An example would be if I were playing SoundCloud where (as far as I know) it doesn't link up through your local wifi, would that still work through Bluetooth?
Hope that makes sense.
Many thanks
Many thanks
