ardnox
I recently bought a Kef LSX system, it sounds great but the remote is bugging me... I have it set up as TV speakers either side of the screen. The remote works but only from a narrow range of angles. I have to be pretty square on to make it work. It also requires loads of presses to make a noticeable change in volume. I’m getting increasingly angry every time I have to get out my chair to change the f**king volume. I’ve never had this sort of problem with amps, TVs, set top boxes - even cheap ones just work. It works much better from the Kef app but I don’t like having to pull my phone out and fire up an app each time just to change the volume.
Does anyone have the same problem? Is it faulty or is it just badly designed?
