I don't use SKY Q and I'm having lip synch issues with both my 4K blu-ray players and Xbox One X so it's clearly the TV which is the issue.Maybe time to give LG a break. Sky Q lip synch is out on the Philips 803. My guess is that there’s something in the way Sky Q outputs lossy DD+ that these sets don’t like.
Yeah it’ll happen on nearly any device attached to the TVI don't use SKY Q and I'm having lip synch issues with both my 4K blu-ray players and Xbox One X so it's clearly the TV which is the issue.
I had no issues with any other input on the C8, only Sky Q. Installed latest firmware this morning and lip synch now perfect on all inputs. S/bar is the LG SK9Y.Yeah it’ll happen on nearly any device attached to the TV
Well that's conflicting information with the about post.I had no issues with any other input on the C8, only Sky Q. Installed latest firmware this morning and lip synch now perfect on all inputs. S/bar is the LG SK9Y.
My lip sync problems only really started with the Virgin Media STB and PS4 Pro connected to the TV after applying the latest firmware update!I had no issues with any other input on the C8, only Sky Q. Installed latest firmware this morning and lip synch now perfect on all inputs. S/bar is the LG SK9Y.
As I said everything is spot on.What about live TV running though the SK9Y? For me the audio is delayed.
UpdateMaybe time to give LG a break. Sky Q lip synch is out on the Philips 803. My guess is that there’s something in the way Sky Q outputs lossy DD+ that these sets don’t like.
If they just updated the TV so you can adjust minus figures like you could on the B7 this wouldn't even be an issue. It's absolutely ludicrous. I can't even replace mine because the company I bought it from won't replace it unboxed.
I just need to buy a new amp I reckon that has dolby vision pass through.
Technically it's not faulty though. Isn't that where most of this issues are. If I thought there's a version out there that's fine other arc I'd ask for it to be swapped, but judging on this 18 page thread there isn't.If it's faulty, a retailer cannot insist on the original packaging, they only can where you just change your mind
Did you get rid of yours then?It is a fault, just one that is in all sets .It's not fit for purpose.
Makes sense. That was my plan but my pioneer won't update so I can't get the HDR passthroughNo. I have a B8 & all sources route through AVR so it's not an issue for me
Why can’t LG just update the tv so we can all go back to minus as auto is always before lip movements.think I’m going insane with this tv.sold my LG sound bar.got the sky soundbox.still the same.sky q is just broke.needs updated ***
