Gzachery
Hello everyone! I just hooked up my brand LG CX oled and been having issues with the picture presets. The HDMI cable I'm using is the same cable that came with the console and worked just fine with the Vizio M-series this TV is replacing. With the Xbox, all the video features on the console are properly checked off since the console has the ability to read the tv. Well for whatever reason when I try to change the tv's picture pre-set to something other than Vivid, it keeps defaulting back to vivid. This doesn't happen when I use the internal apps of the TV and ONLY keeps changing back with the Xbox input. I also have a One S that I hooked up and it does the exact same thing. I even tried a totally different hdmi cable. Same result! Another weird thing is if I leave the TV's store Demo mode on, the tv will keep defaulting to the demo as soon as I select the xbox port. I've had to turn off the demo mode to keep this from happening. I suspect there isn't a complete hand shake with the console. Anyone have any ideas? I've tried disabling the VRR and free sync on the console and that doesn't help either.
