Have you got an ambient light behind it?Gave the Mission Impossible Boxset a binge this week , enjoyed it all, Fallout with the Imax footage was outstanding....View attachment 1287691View attachment 1287692
Ha! I've seen Janis a few times in concerts. Maybe I met your father in one of them and past him the wine.You're a few years younger than my dad, who can't tell the difference between SD, HD and 4k and can't even operate the Sky/Virgin remote let alone play games.
I guess what I'm trying to say is, did you have an affair with a woman called Janis in late 1980?
Hi guys, just bought the 65" E9. Am wondering whether I can improve the built-in audio by using any parts of my existing 5.1 system based on a 2012 Yamaha RX-R373 AV receiver linked to a Monitor Audio Bronze centre speaker, a pair of Mission M73 floor standers and unremarkable side rears. All a bit old tech I know but seems a shame to junk it.
A key question is whether a 5.1 system or adding extra speakers can be used to augment the built in sound or whether it just replaces it?
Hi wondering if anyone can help.
I setup alexa with my e9 and I use an echo dot to communicate with it. All worked fine then a few days after Alexa would say 'tv is not responding please check the network connection' I went on the menu>connection>link to devices for voice control> Alexa but it just hangs and it just shows the loading icon.
I reset the TV and set it up fresh and it was working again. Now a few days later I have the same issue.
Is my unit faulty?
PsHi wondering if anyone can help.
Is my unit faulty?
I can't help with your problem right now as your message is the first time I've realised you can use a dot to control the TV. Which annoying me now as I've had a dot within shouting distance since before I got the TV.
How did you initially link the 2 together? I'll have a play later and then report back.
I didn't see the film when I first set mine up and was massively disappointed with the sound lol.Yes if you go through that setting on the TV you can set you TV up to be controlled via an echo device. Make sure you have downloaded the lg skills too. I still have the plastic on because I'm planning to wall mount it so don't want to take it off yet.
Sorry its not a great pic, I have my E9 on a stand where the ends over hang about 6" on each side, I like the look and have had no issues at all with the glass.Oh dear that doesn't look good. I dont have an E9 but am considering buying one possibly E9 or C9 55" can't decide.
Did this crack happen over time was it tiny to start with or has it suddenly appeared or thats when it was visible? If I buy the E9 I 'd like to keep it on tv stand/cabinet (not was mount it) so would like to see photos if anyone has of the E9 or C9 on a cabinet.
Hope you get your crack sorted by JL let us know how you get on. Good luck.
Hi guys, I currently have a c8 and after much thought Iv come to the conclusion to go for either a e9 or a CX.
Just a couple of questionS, can anyone tell me if the hdmi 2.1 ports are full bandwidth 4k 120 4:4:4? Im buying this TV to ‘future proof’ for ps5. I understand its all hearsay until 2.1 devices come out. Also can anyone tell me if they came from an 8 series, if the brightness of the e9 is noticeabley dimmer than a 8. Apologies if this has already been covered. Thank you
Don't know if you are still considering...I would certainly suggest a full width stand, E9 is 55"Oh dear that doesn't look good. I dont have an E9 but am considering buying one possibly E9 or C9 55" can't decide.
Mine are still on there, but they're actually at the far end where it overhangs the stand it's currently sat on, so they're doing nothing. I tried them in contact with the stand, but then the panel looked like it was leaning back.Thanks for your help, I bit the bullet and got a 65E9!
Got a reduction off the price, I got one delivered a couple days ago for £2250 from Richersounds. Tv looks brilliant. Love the picture on glass design. It was no brainer to get this model, save £550 over the CX with nearly identical pq. The most important thing to me was getting hdmi 2.1. So I can live without the few extra features that the CX has.
I would say at the moment the picture brightness does look slightly dimmer than my C8 but not by a lot. Could be down to panel variance.
I do feel after playing my ps4 pro, that there is more level of detail and shadow detail in this model over my C8.
Did you guys remove the rubber gromits from under neath the glass or keep them on?
I did remove the rubber things, and my E9 hangs over the edge on each end by about 6 inches.Thanks for your help, I bit the bullet and got a 65E9!
This set up is super clean looking, very nice!!Don't know if you are still considering...I would certainly suggest a full width stand, E9 is 55"
Good evening, I’m a new member of AV Forum, very much a novice, and looking for some help please. I am enjoying life with my 55” LG E9 and think the in-built sound bar does a pretty good job for day to day viewing. However, would like to know if I can directly link ‘rear effect’ speakers and maybe a sub to the in-built sound bar/TV without any other equipment? Just looking to add a more immersive sound when watching movies to compliment the stunning picture! Any help, advice and recommendations (low budget/mid-range and top end) would be greatly received!
You can add a WiSa ( WiSA Certified Speakers | WiSA ) set up but that overrides the inbuilt speakers. And it's not gonna be cheap.
You can add a sub with a wire to add some punch though and maintain the internal speaker.
Or you could get a soundbar that comes with rear speakers. There's some cheaper ones at around £250 that just do basic surround, up to thousands for Atmos systems.
I'm seriously trying with the idea of the Samsung Q90R 7.1.4 set up at the moment
