tbracher
Guys / Gals, forgive me, its been a while since I got anew TV. Also I am a perfectionist and just want to be sure I'm doing things right.
Received this week.. LG 55GX (2020). Wow.
I have a very tricky wall mounted situation where its a struggle to pass through wires, I can get maybe a few HDMI's (thin ones) through.. But I will follow your advice and make happen.. and if I can't then will go to a plan B.. I think I can get at the moment 4x think HDMI cables or 2 'regular' gauge.
WHAT I AM LOOKING TO DO:
I want to use the LG remote... keep it simple. Have no extra BS in the setup, and leverage the LG OS as much as possible. Ideally not have to jump out of the OS an into any work arounds.
I also want to take full advantage of the best sound and 4K I can get from the device.. so being sure my cables, and setup are allowing this to happen and futureproof as much as possible.
WHAT I HAVE AND NEED TO CONNECT:
Any suggestions for me.. ideal setups, changes? Anything to make my life WAY easier? LG of course says to plug all directly to the TV.. Marantz says in the AVR... so I am confused to the best path and need your advice!
Thank you in advance!!
TB
- LG 55GC
- Apple Tv (4k) (I use the apple photos and music.. so the in LG app is nice, but when I want to use apple music I assume I need to go to that external input)
- AVR (Marantz 5013)
- Verizon Fios One Box (Cable TV)
- Nintendo Switch (I never use but want to have room for a game console and not have to go into the wall in the future)
- HDMI cables: Monoprice HDMI High Speed Active Cable - 10 Feet - Black, 4K@60Hz, HDR, 18Gbps, 36AWG, YUV 4:4:4 - Ultra Slim Active Series
- a 5.1 Speaker setup, I don't plan on moving to a 7.1, I don't have the space.
- Is the best plan to direct connect ALL devices to the LG TV with an ARC signal back to the AVR? (I can then control all the volumes of all devices and and the LG remote behaves as a true universal remote?)
- Right now I have ONLY the ARC Hdmi connected and my devices to the AVR, this means I need to goto inputs and it also means the LG remote does not control the devices.. and I can't change TV channels on the LG remote.
- I love the LG TV Guide over the verizon guide. Changing channels does not work a the moment. Do I need to connect the LG remote to the verizon box? or does it on its own communicate through the HDMI?
- Do I have the right cables above? Know that I need to use thin.. I don't have a choice.
- Do I need to use an optical cable?
- Do I need to use the CEC setups? On which devices?
- My fear is to make the entire reworking of wires and end up with somewhat the same result, or trade for other headaches I did not expect. I mean I love not needing to switch to the inputs menu to play a game let's say.. but as I understand it, it makes ZERO difference to do that vs being directly connected,. is that true? So maybe I simply direct connect the Cable Box AND on ARC the AVR... and that's it? And then pipe all else through the AVR?? Or since I use the Apple TV music often.. direct connect all except the game, and then just switch to the game input on the occasion I want to game? This is what I mean.. why connect all directly, vs some.. vs only the AVR?
TB
— As an Amazon Associate, AVForums earns from qualifying purchases —
