KenVal
Established Member
Reading the specs it appears that the main soundbar is taller then the space below picture on my LG 65E9 which is on a table, meaning base of picture covered by soundbar !! Shame.
I have a 55" E8 and it didn't obscure the picture for me. There was plenty of roomReading the specs it appears that the main soundbar is taller then the space below picture on my LG 65E9 which is on a table, meaning base of picture covered by soundbar !! Shame.
I just tested it with the testsounds in systemsettings on the the Nintendo Switch and the sounds came out where they should (L, R, LR, RR, C and Sub). Before the last firmware update (when i got the soundbar and set everything up) the sound from the rears came out the sidespeakers from the bar.Can you double check your settings for me, really don’t think it’s fixed. Just put the Netflix test video on my PS4 and the rears both come from the side speakers.
This is with original sound and Standard sound mode.
I’m using EARC on my LG C9, I’ll try connecting the PS4 directly to the bar and test it again, I’ll let you know.I just tested it with the testsounds in systemsettings on the the Nintendo Switch and the sounds came out where they should (L, R, LR, RR, C and Sub). Before the last firmware update (when i got the soundbar and set everything up) the sound from the rears came out the sidespeakers from the bar.
Th LG shows PCM, is set to Standard and Original Sound from the Rears. The Switch is hooked up directly to the Soundbar.
Just tested my Switch in surround and it’s coming from the sides. Same settings original sound & standard, what firmware are you on? I’ve attached an imagine of mine from the google app.I just tested it with the testsounds in systemsettings on the the Nintendo Switch and the sounds came out where they should (L, R, LR, RR, C and Sub). Before the last firmware update (when i got the soundbar and set everything up) the sound from the rears came out the sidespeakers from the bar.
Look in the LG WiFi app instead of the Google app, under Software Version Information. It is my understanding the recent update left main as 2006170 and took Micom to 2007131. My Micom shows 2006251.Just tested my Switch in surround and it’s coming from the sides. Same settings original sound & standard, what firmware are you on? I’ve attached an imagine of mine from the google app.
Starting to think my update wasn’t the most recent, see image for the numbers.Look in the LG WiFi app instead of the Google app, under Software Version Information. It is my understanding the recent update left main as 2007130 and took Micom to 2007131. My Micom shows 2006251.
Yep, same as me - which is why we both aren’t getting the 5.1 to the rears on LPCM.Starting to think my update wasn’t the most recent, see image for the numbers.
LG have already confirmed it does cover bottom of picture and suggested I balance the TV on a further stand !I have a 55" E8 and it didn't obscure the picture for me. There was plenty of room
Wonder how we manually kick it in, you based in the UK too?Yep, same as me - which is why we both aren’t getting the 5.1 to the rears on LPCM.
Yes, UK. Scoured the net and avforums to see if anyone had any advice on how to force a firmware update on these bars - no luck so far. Please let us know if you get any joy from LG.Wonder how we manually kick it in, you based in the UK too?
I’ll give them a call tomorrow.
This is mine next to my LG C9. Honestly I don’t notice content been cut off from my seating position - it would annoy me if it did.LG have already confirmed it does cover bottom of picture and suggested I balance the TV on a further stand !
Yea I’ll update you once I’ve spoken to them pal.Yes, UK. Scoured the net and avforums to see if anyone had any advice on how to force a firmware update on these bars - no luck so far. Please let us know if you get any joy from LG.
Thank you, here is a screenshot of a couple of posts referencing the Micom update if it helps.Yea I’ll update you once I’ve spoken to them pal.
Anyone with the new update or working LCPM actually from the UK?
Thanks for confirming it pal
That’s weird, any suggestions or did yours just auto update?I'm in the UK and this is my current firmware installed on my SN11
It just automatically updated. I have never seen it update other than when I first plugged it in on the day I set it up.That’s weird, any suggestions or did yours just auto update?
Have you tried removing and reregistering your soundbar with your google account in the google home app? My sound bar started the update in the google home app not the LG appThat’s weird, any suggestions or did yours just auto update?
I’m on the newer one and definitely coming from rears now.Yep, same as me - which is why we both aren’t getting the 5.1 to the rears on LPCM.
