DjDiabolik
model: 49LF590V
firmware: the most recently updated... 3.21.40.
issue:
1. the tv it's turned off in standby.
2. by remote i turn on.
3. if i click on home i obtain correctly the message say it's need to wait the smart app start.
Apparently all it's works..i can watch tv... i can change the input ecc.ecc.
but there's a big trouble:
At the first time and if i press the "Setting" button on remote all tv freeze!!! i can see a "X" on top right of tv but all option it's not appear.
after some seconds the tv it's do something like a self reboot... i can see the screen become black for another 1 and 2 seconds and all come back normally.
after that all it's works.. for example right now thw "setting" menu can be opened correctly and all voice appears correctly. the only things it's apparently reset it's the recent app used or the recent input used, after that crash it's simply says there's nothings present recent activity... it's something like all reset himself.
it's never append whit the previous firmware... it's someone have a similar issue whit your lg tv???
issue:
