Lip sync issues
MarcusPants
does anyone else have issues with lipsync whilst on Dolby channels? Pcm channels are fine (And all fine if switch permantly to pcm through settings) but switch to a channel with a Dolby soundtrack I get lip sync issues? I’m connected via ARC to philips tv and LG soundbar. Interestingly if I use solely optical straight to the sound bar all is fine but use ARC the problem resurfaces (I can’t use optical all the time as I need to use ARC for other sources and the soundbar automatically switches to ARC) . Could it be the TV? the V6 box? Anyone else experienced this issue? Thanks Mark.
JayCee
I doubt there's anything wrong with your V6.
It's more likely to be a TV/soundbar problem.
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
