Quantcast
MAKE MY XMAS! TV audio not working
avnoob213
A/V noob here.
Recently set up a Denon AVR-S740H to surround speakers. Cable box sounds great, but cannot get to connect to TV/netflix/etc. Have tried all the youtube/google searching but cant figure it out. I feel like i am one button/switch away but am not having the luck.
- HDMI plugged into Samsung one connect Box (HDMI - ARC slot). Other end is plugged into HDMI Out -Monitor on Receiver.
- Fooled around with Input assign, other modes but cannot get any sound. Any suggestions?!
gibbsy
You will have to enable ARC on both receiver and TV. Or you could use a second optical out from the TV to the receiver. Go to HDMI settings on the Denon and enable ARC. You will have to do the same on the TV, as well as CEC. Turn both units off and back on to ensure a good handshake.
John7
@avnoob213
You urgently need to check your speaker wiring from what I'm seeing in your photos.
At the speaker terminals, you have far too much bare copper exposed and the wires appear to be almost shorting together. You need to re-make these connections and not strip so much insulation off or put some insulation sleeving on them. At best, the amplifier will trip out, at worst it will destroy the amp if the wires are moved and short together.
Rambles
I also have concerns over the speaker wiring, how do you know which is positive and negative?
John7
I suspect each conductor has a colour coded sleeve to ident. polarity but appears to have been stripped back level with the outer sleeve.
gibbsy
@avnoob213
Oh yes, those wires are an accident waiting to happen.
Similar threads
