Quantcast
Marantz SR 8012, 7012, 6012, 5012 & AV 7704 Owners thread
petetherock
Creating this new thread as the new models come online.
Some info is already on the UK website and also in the US sites:
Marantz UK | SR7012
The AVS site has some info too:
*Official* Marantz 2017 NR1508/1608, SR5012/6012/7012 owner's thread - AVS Forum | Home Theater Discussions And Reviews
Just looking at the 7012, the changes are incremental, rather than monumental..
Key Features
  • 9.2 channel AV Receiver with 200 W per channel
  • 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR, BT.2020 , Dolby Vision and HLG (Hybrid Log Gamma) pass-through
  • 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (incl. Zone 2)
  • eARC (Enhanced Audio Return Channel) support via firmware update
  • Analogue to HDMI conversion and SD to HD/4K Upscaling
  • Dolby Atmos (up to 7.1.4 with an external 2ch amplifier), DTS:X™, and Auro-3D built-in
  • Built-in Wi-Fi with 2.4GHz/5GHz dual band support
  • Built-in HEOS Wireless Multi-Room Audio Technology
  • AirPlay, Bluetooth, Internet Radio, Spotify Connect, TIDAL, Deezer and more
  • DSD (2.8/5.6MHz), FLAC, ALAC and WAV support
  • Audyssey MultEQ XT32, LFC, Sub EQ HT, Dynamic Volume and Dynamic EQ
  • Colour-coded speaker terminals, Setup Assistant, Marantz 2016 AVR Remote App
  • Intelligent ECO mode with off/on/auto setting
  • Advanced multiroom options; 11.2-channel processing with pre-outs for all channels; RS232 Control; Crestron Connected
If you already posses a 7.1.4 amp like it's predecessors, the urge to upgrade isn't huge..
Heos, Auro and some minor changes in DAC are what we can expect..
petetherock
Likewise for the 6012:
Marantz UK | SR6012
Key Features
  • 9.2 channel AV Receiver with 185 W per channel > Enough power to fill big rooms with renowned Marantz sound
  • 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR, BT.2020 , Dolby Vision and HLG (Hybrid Log Gamma) pass-through> Latest HDMI standard for future-proof compatibility
  • 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (inc Zone 2) > Extended connectivity: ready to feed a TV and projector in parallel, and even a display in a second room
  • eARC (Enhanced Audio Return Channel) support via firmware update > eARC supports the most advanced audio formats such as Dolby Atmos and DTS:X via single HDMI connection between AVRs and compatible TVs
  • Analogue to HDMI conversion and SD to HD/4K Upscaling > HD video quality from existing DVDs or analogue sources
  • Dolby Atmos (up to 7.1.4 with an external 2ch amplifier), and DTS:X™ > Immersive 3D sound with effects from overhead
  • Built-in Wi-Fi with 2.4GHz/5GHz dual band support > Improved network stability especially in Crowded-crowded homes
  • Built-in HEOS Wireless Multi-Room Audio Technology > Integrated with other HEOS devices for whole-house entertainment
  • AirPlay, Bluetooth, Internet Radio, Spotify Connect, Pandora, SiriusXM, Napster, Amazon Music, TIDAL, Deezer and more > Access to almost unlimited online music sources
  • DSD (2.8/5.6MHz), FLAC, ALAC and WAV support > High Resolution audio streaming, with gapless playback
  • Audyssey MultEQ XT32, LFC, Sub EQ HT, Dynamic Volume and Dynamic EQ > Delivering the ultimate optimization and equalization for your room
  • Color-coded speaker terminals, Setup Assistant, Marantz 2016 AVR Remote App > Hassle-free installation, setup and operation
  • Intelligent ECO mode with off/on/auto setting > Energy-conscious without compromising on performance
  • Advanced multiroom options; 11.2-channel processing with pre-outs for all channels; RS232 Control; Crestron Connected > Audio and video around the home; expandable surround; ready for 3rd Party Home Automation systems
petetherock
Raise up your hand if you think that the new series is a bit of a much ado about not much:
Marantz Unveils SR7012, SR8012 AV Receivers and AV7704 Processor with Alexa Skill
Alexa is the selling point?
However the 8012 remains a piece de resistance..
It's clear by the massive toroidal power supply, dual heatsinks, and monobloc amplifier construction that Marantz is returning to its roots in emphasis in "sound quality first" in AV receivers. We say a decline lately in AV receiver power supplies since the introduction of Atmos. Unlike the other models in the Marantz line, the SR8012 does NOT share a common architecture to sister company Denon counterparts. Instead, this appears to be a completely new design exclusive to Marantz at this time. Seeing the build quality of the SR8012 restores our faith that solid amplification isn't dead in AV receivers. This looks like one tasty amp section that we can't wait to get on our bench for testing.
drillo
Is there any reason to think the 8012 is going to sound any different to well even the 4311, 4520, 7200, 7010,7011,12 - i.e. anything at from d&m since audessy xt32 was introduced forever ago?
Ok yes HDAM but that been in recent marantz offerings, yes it's toroidal but if u use an external amp for front 3 then pffft. Just feels like same old thing - audessy is so long in the tooth. The app might add some ability to custom tailor the sound but I thought we'd see a real departure from the same thing we have had since what 2010,11? Am I alone in thinking this?
Thatsnotmynaim
I think the 8012 has monoblock amps like the Denon 6300/6400 and an extra 2 amps compared to 7010/11/12. If you use all or part external amps then it may not be all that. I guess it’s just a nice one box solution Denon have had for a few years with the Marantz twist.
drillo
I see I'm not alone but am one of 2 he he....
I really feel like audessy has made zero progress in 3-4 years save for ye olde app
Was thinking of switching to Arcam but I use Dolby volume so extensively for night listening
Mobe1969
Hmm, I've never heard of Dolby Volume. I've just googled it and it sounds exactly like something I need. I so often sit with remote in hand ramping volume down and up. Shows like Hawaii Five O is so painful. So not all new receivers have this feature?
drillo
Wouldn't know ratio that have it vs don't but in some case, even those that have it like Arcam 390,550,850 can NOT deploy while Dirac is operational
dante01
Dolby Dynamic Volume is simply processing applied to the audio that compresses the dynamic range relative to reference volume in order to make quieter aspects more audible at lower listening levels (not exactly how Audyssey address this issue, but this is the gist of it). Most receivers include similar processing options even if they do not uinclude Audussey room EQ or Dynamic Volume.
Mobe1969
Thanks. I've seen the Denon and Marantz have the Audessey equivalent, but the Onkyo units don't (at least I can't find any reference).
dante01
Onkyo dropped Audyssey several years back in an effort to cut costs. THey replaced Audyssey room EQ correction with their own, somewhat sub standard AccuEQ room EQ correction and calibration system. I've no idea as to what form of "Night Mode" or similar they replaced Dynamic Volume with?
dante01
EDIT
ONkyo include what they term a "Late Night Function"
Late Night:
Make small sounds easily heard. It is useful when you need to reduce the volume while watching a movie late night. You can enjoy the effect only when playing Dolby series and DTS series input signals.
• The setting cannot be used in the following cases. – If "Loudness Management" is set to "Off" when
playing Dolby Digital Plus or Dolby TrueHD
– When the input signal is DTS:X and "Dialog Control"
is other than 0 dB
This seems rather limited though when compared to Audyssey dynamic Volume which can be applied to any audio format.
drillo
If circumstances are such that you need it - like me for night listening or if neighbours are home - the difference it makes to the sound can be phenomenal. In my room it's the difference between insipid lifeless sound at -45db and very pleasing sound at -45db
Mobe1969
EDIT
Thanks for the info.,that was what I was looking for. Yes I read that it was just one level as well. Their manuals are so bad I wasn't sure if they just didn't go into details.
petetherock
From all accounts so far in other forums, the 8012 will be using the HDMI 2.0b - like it's brethen from the 2017 series.
So for current owners of the x011 and x010 series, the impetus to upgrade is a lot less.
It also uses a similar DACs and it's main draw is the toroidal transformer, plus the extra two channels. Unlike the Denon 8500, it's ability to process more channels and have separate setups for different sound formats seems to be limited..
The concept of this amp is still very tempting.
Take choice parts like the HDAM modules, Caps and Toroidal from similar models, ala the PM 11 S3, using similar processing chips ala SHARC and DACs from what has been in use already and slap on a higher price tag... let's see how much it costs in the shops....
gigicoltz
So,in your opinion, Denon 8500 is better than 8012?!
petetherock
That depends on a few factors:
HT vs music
How many channels do you need and is switching important
How much power do you need
And perhaps most important, how deep is your pocket.. the 8500 will cost more than the 8012, and I don't think it's a marginal difference.
For a lot less than both of them, the 7012 does most of what the two can handle, and if you need the extra two channels, there are other options. Even if you add a nice stereo amp with a HT bypass option like the PM 8005, it will still be more cost effective.
In fact if there are BNIB run out sets of the 7011, they may be the best value ...
So YMMV..
gigicoltz
HT vs music
So YMMV..
Thanks a lot.
What is HT?
Speaking about music, is it better to have a Marantz instead of a Denon?! Is that difference really so bold?
I owned a Denon X2300W, now I have a Marantz 6012. My impression is that in movies, Denon was much more punchy, impressive,moving... The subwoofer was better addressed. Or is my experience-less attitude? Or I did a wrong setup in 6912?!
Scamm0r
I've got my eye on the Marantz SR5012 as an upgrade that has been 15 years coming. For the time being it will be paired with a pair of stereo Gale 3030 floorstanders. Are these going to play together ok? Will I be able to bi-amp? :)
petetherock
Thanks a lot.
What is HT?
HT- Home Theatre
That's why it's best to audition before one commits..
Rambles
Yes, they will work, but for stereo you would likely be better off with a stereo integrated amp. You will be able to bi-amp if you want to (well technically, bi-wire, as you need two amps to bi-amp), but the general consensus is there will be little benefit, and good quality speaker links should achieve the same results.
Scamm0r
Heh. I've been round and round (and round!) for a few weeks now and posted multiple threads on here and elsewhere trying to figure out what's best. Long story short, I'm currently using a Marantz PM6010 stereo amp that is on it's way out (powering off randomly, losing left/right etc. it is >15yrs old!). However, I have 6 HDMI devices so really want to upgrade to an AVR to simplify my setup. It's currently a mess of inputs directly to my TV, a splitter, and even swapping out a HDMI when I use the Apple TV. It's basically horrible and the other half gives me a lot of stick over it. On top of that, I got a Google Home and a Harmony Ultimate for Christmas -- so I want to be able to walk into my lounge and say "Hey Google, turn on the TV" or "turn on the Fire TV" etc. That's the dream.
As far as quality is concerned, yes I care about music more than movies (I listen via Google Play Music on Chromecast), but I really need that simpler setup going forward. It's just a bodge right now. Hence why I want to stick with Marantz, and pay a little more for what will hopefully be a better musical experience than say, the equivalent Denon.
I thought about getting a cheap AVR with pre-outs for a stereo amp, but I feel like that would be difficult to manage, and indeed it's hard to find a "cheap" AVR with preferably 7 HDMI inputs. The other option would be a decent splitter/matrix, but again it doesn't simplify the setup, and won't get rid of some of the other niggles I currently have like Netflix/FireTV not knowing if it's full-range RGB or video range. Stuff like that.
Similar threads
Trending threads
Latest News
Philips OLED burn-in solution is 95 percent effective
  • By Andy Bassett
  • Published
Philips TV’s with HDMI 2.1 and Dolby Vision IQ due in time
  • By Andy Bassett
  • Published
Sonos clarifies product update and recycling position
  • By Andy Bassett
  • Published
Philips 4th Gen P5 processor adds AI for more realistic images
  • By Andy Bassett
  • Published
LG regards HDR10+ as unnecessary
  • By Andy Bassett
  • Published
