Hi All,
Currently having an issue with my 6012 and LG B7..
All sources work as expected, except for the 'TV Audio' input, so anything directly on the TV i.e netflix\prime etc..
It started about 3 weeks or so ago after a firmware update... Audio worked ok, but just couldn't get other arc functionality, turn volume up and down on all controls, power on\off using one control etc.. ended up plumping for a harmony elite (always wanted one anyways). Issue now is that i 'sometimes' get audio via HDMI, the other day it worked fine. However last night just couldn't get any audio, turned arc on/off on both AV and tv, no difference. Ended up having to change to use optical.
ANyone have any ideas\advice why this may be?
Replacing the HDMI cable can sometimes resolve some HDMI ARC issues. Newer HDMI cables tend to work better than older ones when it comes to ARC. It is also recommended that you use a cable rated as being at least HIGH SPEED and maybe even look at one officially categorised PREMIUM. THis is by no means a guranteed fix, but probab;y worth a try.
Also note that quite a few people have been experiencing HDMI ARC issues with both Marantz and Denon AV receivers of late and these issues do appear to have materials when D&M started introducing eARC compliance? It may be the case that these issues are as a result of the updates and may require either a newer firmware revision to recify them or flashing the firmware to an earlier version until a fix is posted by D&M?
I have an sr8012 and 7.1.4 setup,
Which sound setting on the marantz unit for atmos compatible bluray should I choose. I do not see the word atmos on the marantz sound setting menu, only stereo, virtual stereo, neural x, auro2d, Dolby surround 7.1, multi in Dolby surround,
I press the movie button on the receiver and it scrolls through the above options.
I have all 11 channels set up on the marantz ok and performed audessey
Thanks in advance
Thanks in advance
When this happens turn the power off at the wall, I have had this happen on occasion, how did you get it to program to the sky q remote?My 7012 has played up today. Went to turn it off this morning and unusually I used the Marantz remote, I normally use the Sky Q remote. The amp switched off but it didn't turn off my Emotiva power amp as well like it normally does. I switched it back on again and now there's no signal output to the TV and it still doesn't switch off the Emotiva , turned it all off and back on again at the plug and no change...going away for the weekend so have left it off and will try again on Monday. Anyone else had an issue like this?
I use the Sky Q remote to turn off the TV which in turn, via the HDMI connection turns off the amp. Going to try a factory reset as I have turned it off at the wall but it hasn't solved the problem, I also noticed yesterday that it isn't switching off my subwoofer either!When this happens turn the power off at the wall, I have had this happen on occasion, how did you get it to program to the sky q remote?
Anyone any advice?...Taking delivery of a new 7012 tomorrow. Obviously going to go through the manual and take it slowly in setting up, but just wondered if there was any initial advice on achieving a smooth change over from our old Pioneer LX83 receiver system which is going in part exchange?
Other components in our system:
Panasonic 65FZ802B 4k OLED
Samsung HW-MS650 soundbar (used for general tv watching/listening)
Panasonic DP-UB82EB0 4k Blu-ray player
Sky HD 2TB
Sony VPL-HW55ES 1080p projector
Oppo BDP-103D Blu-ray player used as a CD player now! (used previously for films when we had a Pioneer LX5090 Kuro 1080p plasma)
Our speaker system is Monitor Audio Silver 8 floorstanders, Silver centre and Silver FX surrounds and RSW12 sub. We also used a Rotel RMB 1075 5 channel power amp which was combined with the LX83 to bi-amp the Silver 8s and power the centre
We will eventually try a full Atmos set-up, but not sure if it will be 5.1.2 or 5.1.4 as our seating is hard against the rear wall of the room so 7.1.2 or 7.1.4 is probably not achievable. Might still use the Rotel in conjunction with the Marantz
I want to make it as wife friendly as possible as I had to muck about with the cabling when we wanted to watch Sky through the projector previously. And also a few other sound issues were a bit confusing. I didn’t do any pass through with the LX83 as it didn’t do it!
Any thoughts would be most grateful
PA
How did you get on with the swap?Taking delivery of a new 7012 tomorrow. Obviously going to go through the manual and take it slowly in setting up, but just wondered if there was any initial advice on achieving a smooth change over from our old Pioneer LX83 receiver system which is going in part exchange?
Sky HD 2TB
PA
Hi, anyone know what the letters SG are for at the end of the amps name?, i.e Marantz sr 6012 SG.
There is a 2 Chanel setting in the setting menu, probably under audio,you can set with sub or without.Does anyone know how to have just the Front left & right speakers plus the sub for music? The stereo setting doesn't use the sub and every other music setting seems to enable full surround sound.
Thanks - I can see that setting but how do you implement it when playing music over Airplay? The only two options I can see are the 'Pure' button or 'Stereo' from the music button - both of which just enable the left & right speakers and not the Sub.There is a 2 Chanel setting in the setting menu, probably under audio,you can set with sub or without.
