Hi, I’m trying to make it work on a Marantz UD5007, and have the files, but can’t make it work. What type of USB thumbdrive you need, NTFS, Fat32, exfat?
And where do you put the auto script folder? It does nothing.
hope someone can help, thanks in advanced!
EDIT: never mind, figured it out, actually if I had followed the instructions correctly it would have worked the first time.
USB FAT32 place The Autoscript folder in the root, with the autoscript file inside.
I just needed to press the number, I wasn’t doing it.
Thanks anyway.
