No I don't use a minidsp, I edited my post to clarify the specs btw. I doubt it can be solved in the same way using that device unfortunately.
Thank you @mattkhan I really appreciate your help
Is this a DF sub, possibly one that used to have a plate amp? Did you ever try a power cable without the earth pin?Well I don't want to curse it, but since I installed it I haven't heard the hum.
Easier said than done. The Receiver is in the lounge, the Inuke is in the loft.Run a decent piece of wire from earth binding post on your receiver to the case of the inuke. Should sort it.
Well, I tried moving stuff about and different sockets, NX 3000D is definitely the culprit, I’ve ordered one of those Hum destroyers, So I’ll see if that works tomorrow.I don't know. Probably easy enough to try it in both places to see which works.
Hi there,
I know this is an old topic now but did you manage to sort the noise? I still have mine I am having to turn the inuke gain to 2 o'clock location on the front in order to tame it. It is the most annoying sound ever lol.. faint but when you know it's there it's always there.. I am not sure if this is something to do with the miniDSP 2x4HD being in the chain or if it is actually the inuke attenuating the noise.. I'd really appreciate if you or anyone else on here who may have an inuke and miniDSP combination assist in how to resolve this issue for good. Thank you
Our hum turned out to be having the miniDSP HD in the chain, I solved it by running a wire from the ground screw on the miniDSP (next to output 4) and wedging the other end into the usb port on the back on the NX3KD, It worked for me, But you could try one of the case screws on the amp.
Hope this helps
View attachment 1369022View attachment 1369023
To update the thread regarding the Hum destroyer mentioned here, It did nothing for my situation and is now gathering dust in a draw .
But that's not to say it won't work for everyone , Just that the above solution worked for us.
I can't claim all the glory , It was suggested to me by various forum members to try the ground screw on the mDSP, When i touched the other end of the wire to the outer part of the usb socket, The hum stopped, So that's where it's stayed .Thank you that is a very interesting find I will definitely try this and report back
