PascalP
Established Member
Nice! Wondering how a .6 Atmos layout sounds. How does it mix a .4 track?
More speakers 6 total in ceiling MKIW150 another SDA2400 and better lights and poor photography.
However it's sounding great and the bedroom is finished now, but it just has an OLED in it which isn't exactly exciting, I did consider a small TDAI 1120 system but there was too many weird angles in there.
From the bedroom door.
Looks great Ross, any chance of some more pics showing the 6 ceiling speakers?
I'll give it a go tomorrow, I mean today.
Thanks! There’s something quite comfy about having all your kit in a lounge like environment, like you have, that you can just sit on your comfy sofa and start watching a movie. My setup was like that. With a dedicated room, there’s almost a formal atmosphere to it.
Anyway, it looks ace!
Thanks bro. This is my office, so I had to make some sorta balance and not have it a batcave. So it's dark enough not to blow out the contrast and 'liveable in' Had I put cinema seating in, it just wouldn't work - I'm not keen on the 1 or 2 rows of standard black cinema seating - I think a couch is better, because you don't have to be bolt upright.
The big bay and small window behind me give enough natural light during the day if needed too.
There's still some small aesthetic changes to make, like a ceiling mount for the PJ , maybe have to move the back spotlight, in which case I'll just add another set in ceiling.
And then it's gotta be repainted, because this vinyl matt, if you touch it, it'll marr so it needs a different version of the same paint.
Which might prompt me to do a split on wall rack system behind the AT screen care of @Seriously Ltd He's done a few sneaky rack jobs inside cabinets etc. So I can sell on the Anthem A5 and one SDA 2400, put in a Lyngdorf MX8400 - so you get the best of amplifiers, hidden, no heat or explosions.
The whole house needs rewired - I've have 14 things running on a double socket that all goes back to an old school fuse box, not an RCD style thing, so there isn't any protection anywhere in the house strictly speaking. So a 30A line will go in, the noise floor in here is deathly quiet so I'm not expecting a sound improvement.
Nearly there.. I organise so many things for others, I'm just beat by the time it has to be my own sh*t.
Anyone wondering, there is a server, centre speaker, media player and xbox series x behind there, network switch, modem, router, hue hub, dead badger.
I think your room just consolidates my thoughts on keeping a multi use area that veers more towards av use.
You’ve been fortunate with the electrics so far! Next update is right there!
Kit wise, once you have the Lyngdorf amp, you’re kind of there then? Other than the touching up and non kit changes?
I’m going to have a nosey at your previous pics with more light in the room
Impressive setup and room. Do you use the SDA2400's for low frequencies only, or also for mid and high freqs?
You’re fortunate to have a good bit of distance between the sofa and the rear wall so the back speakers can breathe a bit.
Could you do with having the sofa a bit closer to the fronts for the equilateral triangle positioning? Not that it’ll make much difference with Room Perfect sorting everything out...
Why didn’t you put all three front speakers behind the screen? L/R too close together?Shouldn’t RP take care of that?So Gert the speaker designer and one of the best system setter uppers I've seen, said it would be ok. Technically speaking I need another 2ft.
And yes I could move closer, but I can't move my surr left any further or it would be mid air in the bay window area. So there is a slight compromise, but I don't believe it's audible in comparison with similar systems in other rooms.
^Class looking room by the way, plus a killer sound system. I know it’s a bit corny but since your bedroom leads to the cinema room when showing people your home you should show them the bedroom first and then open the door to the cinema room and say “this is where the real action happens”.
I don’t know if you are aware of the self adhesive flock that ABM sell but it’s been brilliant for me plus it sticks to the walls and ceiling so flush like wallpaper.
