Timme
Established Member
Yeah just stick with what you have and save your money.
Thanks!
I will! But I will get another T758 for downstairs where I’ll have my home theater
The StormAudio processor, maybe? Not sure
Nothing a MiniDSP 2x4 can't fix
Dropbox - MiniDSP 2x4 Set-Up Guide Latest Version.pdf - Simplify your lifeAny guides on setting up MiniDSP 2x4 with the T758 to run dual subs? I have dual subs at the moment which is just run from the single output and split, but I've heard the MiniDSP 2x4 is the way to do it properly but dont know much about it.
Appears the dirac sub module will not work on the nad...according to avs
I think that's only based on one person who asked a Nad rep, wouldn't be the first time a company rep has got it wrong, having an Arcam taught me that much - time will tell.
Also rumours of new Nad AVRs this Autumn!
Is MSO a separate module? Better value the. MiniDSP 2x4?Indeed, let's wait until the Dirac modules are actually released before we jump to any conclusions
Either way I'm not too fussed, MSO has done a fantastic job with my subs
It's (free!) software that calculates values to input into your EQ device, ie: a MiniDSP 2x4 (or 2x4HD)Is MSO a separate module? Better value the. MiniDSP 2x4?
Plus a phd in quantum physics just to understand how to use it.....unless your a professor.
Some people just want plug and play...
Tbh ive started looking for alternatives to the nad..., nothing wrong with it i dont have time to spend years getting it dialled in anymore, lifes too short
Thank you!It's (free!) software that calculates values to input into your EQ device, ie: a MiniDSP 2x4 (or 2x4HD)
Multiple Subwoofers: Optimize Them With Multi-Sub Optimizer Software
I was talking about mso....it is easy to set up on the nad for sure...im just not % happy with the lack of bass...ive put every harman in meh....
That didn't stop Arcam...It’s a work in progress and it’s not ready for release
Ahahahah! So true unfortunatelyThat didn't stop Arcam...
How do you do that then?
Its Easy to set up just the NAD and one sub but maybe it’s a lot harder with two?
Is it normal for Dirac to always set the sub delay to 0 and just add the delay to the other speakers ?
Thanks.Nah, it's easy
Yes, the sub is often the furthest away (and almost always will be due to the delay in the sub's DSP processing) so other speakers that are closer are delayed slightly so all the sound arrives to you at the same time
Morning all, I've been looking at the T758 v3 for a while now, watching the bugs and issues come and go. Are we pretty much bug free now?
I have a few questions:
The plan is to get rid of my Yamaha RX1050, Yamaha A-S1100 and Cambridge 851N streamer and replace with this box, mainly because the Mrs isn't keen on multiple boxes. Has anyone gone from having a setup they really like to one of these current Nad AVRs, is the sound quality really that much better because of Dirac? As much as I like the 851N, I do find the interface quite clunky, mainly because it doesn't use the TV screen, does BluOS let you use the TV screen while listening to music? I have seen it on tablets and phones, but not on the TV.
Also, on the 758, can I listen to stereo music streamed from NAS via BluOS in 2.1 with my sub?
Does the upgraded Dirac on the 758 mean that I no longer need an Anti-mode?
Thanks, I'm sure there's more I need to ask, but this will do for now, cheers
