Stringybob
Hi, I am new to this Forum and just after a bit of advice please. I have recently acquired a second hand Naim Nate 5i integrated amp to upgrade my old (and relatively cheap) Cambridge Audio amp. I use 3 inputs to the amp. The main one I use is my Pro-Ject Debut Carbon turntable through a Rega Fono Mini. For convenience I have a Chromecast Audio. I also have a cheap DAC converter to connect the Optical output from the TV. All of this worked fine with the Cambridge Audio amp into my cheap and cheerful Cambridge Audio Sirocco s30 speakers (which will be upgraded next).
The problem I have now is that the Chromecast is fine when it is connected i.e. the amp is silent with zero hum. However as soon as I connect either the Turntable or the DAC, I have a relatively loud hum on all of the channels.
Does this sound like a problem with the amp, or is it a problem with compatibility with the speakers? Any suggestions would be gratefully received as I am tearing my hair out!
