Orcrone
I have a Harmony Elite hub & remote which I control from the remote or via Google Home voice command. I wish to have a system where I can press a button (or issue a verbal command) and all the required HT equipment will power on and the lights will turn on/turn off or dim as I program.
First I tried TP-Link products. I used Samsungs Smartthings and eventually, using the help I found here, was able to do what I wanted. However, I could not get the dimmer to work properly. So I decided to go another route and purchase Lutron Lighting products. However, the only ones I can find are the Plug-In lamp dimmer switch for $44 each.
I don't need the dimmer so I am looking for advice as to which smart plugs to go with.
Thanks!!!!!
Thanks!!!!!
