DREADKNOT2077
I WANT BUILD A 3-WAY CROSSOVER AN A GUY AT PARTS EXPRESS
SAID I CAN USE THER HIGH AN LOWPASS FILTERS TO CUSTOMIZE MY OWN DESIGN EVEN STACK THEM TO GET 24-db-octave
BUT I CANT VISUALLY WRAP MY HEAD AROUND HOW
PLEASE IF SOMEONE COULD SHOW ME IN A DIAGRAM HOW TO PUT THESE PARTS TOGATHER TO MAKE A 3-WAY CROSSOVER AN WHAT ELSE I NEED ALSO THIS IS WHAT I WANT TO ACHIEVE
600 WATTS RMS INPUT 8 OHMS WITH 200 WATTS TO EACH SET OF DRIVERS - LOWS ,MIDS,AN HIGHS
WITH THIS CROSSOVER CONFIG - 2000HZ / 6000HZ ALL WITH 48DB OCTAVE SLOPES
_________________________________________________
MY DRIVER PICKS ARE
TWO - B&C 10PLB76 98dBSensitivity (1W/1m) 10IN 8OHM WOOFERS WIRED TO 4 OHMS
__________________________________________________________________
TWO - PRV Audio WG275Ph 1" Horn Loaded Midrange 8 Ohm SPL: 106 dB 2.83V/1m
WIRED TO 4 OHMS AN (to be attenuated 8db )
ONE - Visaton HTH 8.7 Professional Constant Directivity Horn 8 Ohm AT 8OHMS
WITH AT SPL: 106 dB 1W/1m ( to be attenuated 8db )
CROSSOVER PICKS ARE
_____________________________________________________________________
TWO OR FOUR OF THESE "Parts Express Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm" from www.parts-express.com!
FOUR OF THESE - "Dayton Audio 2k-LPF-4 Low Pass Speaker Crossover 2,000 Hz 12 dB/Octave" from www.parts-express.com!
FOUR OF THESE - "Dayton Audio 6k-HPF-8 High Pass Speaker Crossover 6,000 Hz 12 dB/Octave" from www.parts-express.com!
MY DRIVER PICKS ARE
Home
PRV Audio WG275Ph 1" Horn Loaded Midrange 8 OhmThe compact and convenient WG275Ph from PRV Audio combines a wide dispersion bi-radial horn with a powerful midrange compression driver. This combo has been specifically designed to reproduce the all-important vocal range with authority. With 60° H...
"Visaton HTH 8.7 Professional Constant Directivity Horn 8 Ohm" from www.parts-express.com!
CROSSOVER PICKS ARE
