psikey
Outstanding Member
In last week I bought a pre-built gaming machine from ebuyer (usually build my own) which is built on the ASUS Prime X570-P motherboard with 3800X CPU, 3080 GPU and boots from a Seagate Firecuda 4.0 NVMe m.2 drive.
Strange boot issue.
When its first powered on it boots fine.
If I Restart it boots back in fine
If I power off then start some time later it seems to go past BIOS but then never boots Windows and just sits at a blank screen. If I press reset button it starts fine.
I just tried disabling fast boot but didn't make any difference.
When PC is off there are still RGB lights lit on the motherboard itself (maybe its still partly live for say USB charging when off).
Any ideas before I attempt to get any sense out of ebuyer support?
Strange boot issue.
