My 4K stick is connected directly to a Yamaha receiver. I've suddenly started to get audible crackling when navigating around the Youtube top menu. Playing files is OK but crackles as I navigate the menu. The same app is fine on a Roku connected in the same way.
Anyone else with similar, or a solution, before I re-download the app?
Mine is also connected to the back of my RX-A1070 and navigating through the screens I do get an audible "click" because I haven't disabled this in settings. Any chance this is what you are getting?
Watching Jack Ryan season 2 at the moment and have had to switch back to the internal app in my C7. The lip sync is not right through the Firestick, only seems to affect this series and I can’t find a way to correct it. It’s perfect with the C7s app.
Its very odd. I don’t understand what’s going on.
Jack is ok in Atmos from an audio perspective to me. But I’m a bit brassed off with the cluttered interface and YouTube crackles so going to have another crack with ATV. Especially since they are bundling their TV service for free at the moment.
Yeah, the interface is cluttered and gets worse depending on what’s in the recents row. It ends up as a jumbled version of the your apps and channels row for me. It’s annoying.
Apple TV+ is turning into a bit of a disaster on it too. I’m getting loads of noise and posterisation which I’ve never seen before with any 4K stuff and frame skips too. I’m told none of that is happening on the ATV, so I might be headed that way too.
I‘ll have to believe you on that one. The Firestick is connected directly to the TV which says it‘s receiving 2160p with the auto setting
Anyway I’ve tried it and noticed two things straight away, even allowing for a bright room the title sequence for See still looks dreadful and at 2160p 50hz it now has masses of added stutter. Changing the output to 2160p 60hz seems to have cured the frequent stutter, I’m now getting just occasional stutters like before, but has done nothing to improve the picture noise.
Perhaps I have a faulty Firestick, the issues I see are very TV specific, or I’m very fussy. Don’t know which.
My Firestick 4k will only output 8bit HDR video whereas the Firetv Pendent I have outputs 10 and 12 bit.
The screenshots below are from my 2019 Philips Oled info screen which supports HDR10+ although any HDR has the same issue, not including Dolby Vision as I believe that is carried inside an 8 bit container. Both were playing Carnival Row
Both Fire TVs have exactly the same video settings and both were plugged into the same HDMI port on the TV alternately.
First pic is the FireTV 4k 2nd is the pendant and the third is for info from appleTV+ sideloaded to the Pendent.
I factory reset the Firetv 4k and still the same.
Can anyone explain this and if possible check their own 4k stick.
Could my stick be faulty although I don't see how?
The video on the pendent is far superior to the 4k stick even though there is no DV on it.
Hi. I am new to Firestick. One of my favourite websites will not work on Firefox because Ff operates an Adblocker, or so the message says. Can I disable this or perhaps install another browser?
Thanks. My primary motive for getting Firestick was to have a browser that will play videos from a show jumping website. They have an app but its functionality is well stripped back.
Has the Netflix 24hz frame rate been resolved on the 4k stick yet? Only it's currently £29.99 if you order it through your Alexa speaker or phone app and been considering it so I can switch off the annoying ARC..
I don't think so Paul, I was trying various programs and settings the other day on my 1080 TV and all I could do was change the motion issues from bad to worse. And that was on prime not Netflix!.
Thanks, is it just the 4k Firestick or all of them? Only I have the 1080p Firestick but I rarely use it as I have the apps built into the TV now, so might have to try that out and see.. I was thinking of getting an Apple TV box but there's quite a price difference and if I can get 4k through the ATV+ app on the Firestick and get 4k with Disney+ when we get it I think I'll be happy, especially if I can switch off the ARC setting as my amp keeps defaulting to TV Audio everytime I switch it on which becomes annoying (I've even set a delayed input command on my Harmony which sometimes works and other times doesn't)
you may not have any bother, a lot of people aren’t with4k, I only have the hd Netflix sub now so I can’t try anything 4k on the projector. most don’t seem to have any issues with 60hz, one program I tried that had judder with match frame rate on was 30hz according to the marantz video info page... it all seems so complicated but shouldn’t be!.
Strangely, my AVR (Pioneer LX303) has recently started defaulting to TV audio when I switch it on. I also have the B8. I have always declined the LG updates when they pop up, so I assume my AVR must have updated at some point to cause this issue.
Thanks, if the ATV+ app was on there I probably wouldn't bother with the 4k Firestick but it seems only the 2019 LG models are getting the ATV+ app, I still prefer the Firestick voice commands over anything else though.. much better than the LG voice commands that always end up doing web or Youtube searches, whatever you ask for lol
