OPPO Smart TV S1 65" 4K QLED 120Hz - Unboxing ( OnePlus TV Q1 Pro Clone ?! ) 65 Inch
S1 Specs
• Panel Type: QLED quantum dot
• Resolution: 3840×2160
• Local dimming: 210 zones
• Color Gamut: NTSC 120% (typical value)
• Peak brightness: 1500 nit
• Refresh rate: VRR 100 Hz/ 120 Hz
• Low blue light certification: TÜV Rheinland low blue light certification
• HDR Support: Dolby Vision/HDR10+/HDR10/HLG
• Size with base: 1445mm(L) x 898mm(H) x 301mm(D)
• Size without base: 1445mm(L) x 832(H) x 70mm(D)
• Weight with base: 29.8kg
• Weight without base: 26.6kg
• Speaker: 5.1.2 DYNAUDIO featuring 18 units @ 85W
• Dolby Atmos support: Yes
• Processor: MT9950 Quad-core A73 1.8GHz
• GPU: G52 MC2
• RAM: 8.5 GB
• Storage: 128 GB
• OS: ColorOS TV System
• Camera: 1080P built-in with lifting camera
• Remote Control: Breeno voice bluetooth remote control featuring Far-field speech
• WIFI: WIFI 6(802.11ax)
• Bluetooth: Bluetooth 5.1
• Ports: HDMI 2.1 x 2, HDMI 2.0 x 1, (The HDMI 2 port supports eARC), USB 3.0 x 2, LAN x 1, Optical x 1, AV audio and video input (Mini 3in1) x 1, DTMB (analog/digital TV interface) x 1
• Power Consumption: AC220-240V 50/60Hz
• Max power 400W
• Standby power <0.5W
• Energy efficiency rating: two
R1 Specs
• Panel Type: LCD, 10 Bits(8 bits+FRC
• Color Gamut: 93% DCI-P3, 10.7 billion colors
• Peak brightness: 300 cd/m2
• Refresh rate: 50 Hz/ 160 Hz
• HDR Support: HDR10+/HDR10/HLG
• Speaker: 2 x 10W Dolby Audio
• Dolby Atmos support: Unknown
• Processor: MT9950 Quad-core A73 1.4GHz
• GPU: ARM Mali-G52 MC1
• RAM: 2 GB
• Storage: 32 GB
• Bluetooth: Bluetooth 5.0
• Ports: HDMI 3.0 x 1, (The HDMI 2 port supports eARC), USB 2.0 x 2, LAN x 1, Optical x 1, AV audio and video input (Mini 3in1) x 1, DTMB (analog/digital TV interface) x 1
Source:
Oppo Launching S1 and R1 4K Television Lines - The FPS Review
