WiscoAV
I purchased an Onkyo TX-NR797 yesterday for my Optoma UHD65 projector setup. I've tested both of my HDMI cables by directly connecting the Xbox into the projector and had no issues. Now after using my Onkyo for my AV/sound system, I have run into multiple errors from a video perspective:
Watching movies & TV:
- Your TV setup DOES support 4K 10-bit at 24hz.
- Your TV setup doesn't support 4K 10-bit at 50hz.
- Your TV setup doesn't support 4K 10-bit at 60hz.
Playing Games or Capturing games:
- Your TV setup doesn't support HDR10 for gaming.
I've changed the settings on my Onkyo receiver to auto upscale and performed a firmware update but no luck. Also, I know the UHD65 doesn't support Dolby Vision, so I am not concerned about getting that to work.
Hoping this thread can help me out, cause I am lost and would like not to return this product! (If I have too - please recommend some products that wont have this issue)
Thanks!
WiscoAV
Thanks!
WiscoAV
