Dragged my old Mission floorstander speakers, Rotel amp and Sonic Link Red cable out of loft to use with new QLED Samsung TV. Connected using Cyp Dac, and QED RCA and interconnector cables, Initially, when using Aux setting on amp there was a scratchy static sound from both speakers, but a bit of knob twiddling (switching between Aux and Phono on amp) and it sprang into life. Fine. Good sound. But only one speaker. Have swapped over cables on speaker ports on amp (and used Remote Speaker ports) and this swaps the speaker that works. So I concluded that it was not the Speakers and most likely the speaker cable. But, if you turn the volume up on the amp to almost half way both speakers work, but it is deafening! I am now confused, if cable is at faulty, why does it work fine (clear and loud!) but only when volume is turned up? Any ideas?
