Antiquarian
Established Member
And my Samsung, a pre hdr 4K tv. I am aware of the Sony issue though.the only time the oppo is doing the dv processing is for the crappy sony implementation,where there tvs couldn't.
hello guys ,
anyonce can recomnded about kit mod for region free for blurays ?
where can i buy from good seller ?
tanks for the help
HDR10+ works fine. It's been confirmed somewhere within this topic and over on the AVS Forum.
dolby atmos is encoded in the true hd soundtrack,the oppo bitstreams the audio,and any compatible device ie my avr, which extracts the atmos,the oppo has nothing to do with decoding atmos.I have a Panasonic Tv that does HDR10+and Dolby Vision and I know for a fact that my OPPO 203 does HDR10 + but have No software to prove this...what also I find strange is that although the TV has built in D ATMOS speakers when you play a disc encoded with D ATMOS the display on the the OPPO tells me it is outputting TRUE HD ....Any thoughts
When you bought the OPPO it came bundled with a Premium Certified HDMI lead. Are you using it to connect to your Panasonic TV.I have the oppo 205 connected directly to hdmi 2 but the TV is not detecting Dolby vision on any of the disc that I have....
All sorted. I reset the player and all good now but thanks for the advice. Much appreciatedWhen you bought the OPPO it came bundled with a Premium Certified HDMI lead. Are you using it to connect to your Panasonic TV.
Is your OPPO running the latest firmware? Which is 20EU-65-0131 for the UK/EU players.
Would quite like an answer to that one myself.Has anyone used 14TB or 16TB Hard Drive with the Oppo 203 ?
Ok, so video to the TV and audio to the amp is your recommendation, thank you! I think I can recall reading something about a cleaner image on direct video connection too back in the early days of 4K, but wasn't sure if I'd dreamt it.@valmont74 , Direct links will give the cleanest picture. The only benefit of routing via the amp is fewer HDMI leads to the TV. Separate leads to the tv allow you to watch Sky whilst listening to music. A single cable will prevent that. I’d stick with direct connection.
Common problem with The Martian extended cut. Theatrical version seems OK. A number of members got their 4kBluRay replaced apparently.@valmont74 , that reminds me of the same out of sync issue I had watching The Martian on Saturday night. Half-way through it went out. Pausing didn't fix it. Had to eject and then it restarted at the correct place with lip sync okay again. I have separate leads out of the Oppo so it's just a UHD thing perhaps.
Thanks. I can live with it but good to know it’s the disc and not the Oppo.Common problem with The Martian extended cut. Theatrical version seems OK. A number of members got their 4kBluRay replaced apparently.
Has anyone done an AB comparison with a Sonica DAC and a 203? Wondering what the step-up performance in the analog audio would be - as in night/day or slight? Cheers
