isitbroken
Hello
I have a Lamona LAM3301 built in oven which was installed with the kitchen 6 years ago.
It is seldom used as I usually work away for long periods of time hence why I didn’t need a quality brand oven, just one that works on the odd occasion.
The RCD trips after the oven has been on 1 minute or so. It resets easily.
Initially I thought it was one of the elements.
I believe it has the grill/oven top element plus one in the bottom of the oven, but whether I select the grill alone, the fan assisted main oven, the main oven without the fan assisting, or just the bottom oven only it does exactly the same and trips after 1 minute.
Surely both elements wouldn’t go at exactly the same time so I am thinking is it a supply issue? With that said, if it was a supply issue would it not trip immediately-not after 1 minute of warming up?
