PerfectBlue97
- Joined
- Jul 15, 2010
- Messages
- 1,065
- Reaction score
- 72
- Points
- 478
Doesn't sound like a standard overscan issue as that wouldn't result in part of the menu being off screen. The menus and any text are purposely positioned a certain distance from the edges of a screen to avoid overscan issues.
It isn't all menus. Most are OK.
If I go to My Shows, and then select all of the episodes for a specific show with a lot of episodes, the last name on the screen is only just visible, most of it is off the bottom of the screen.
I'm also missing a little bit of the right hand side of the screen most of the time.
It only happens with the Tivo, and not with V+
