Fly_Boy_Rez
- Joined
- Dec 19, 2005
- Messages
- 113
- Reaction score
- 1
- Points
- 62
I recently bought this Blu Ray player from Richer Sounds and tested it on a frineds TV and all was well. The reason I tested it on his TV is because I am an expat in Singapore and bought the player on a business trip (all my discs are region B / Zone B and getting a Blu Ray player in singapore that will play them is rather expensive)
I've now returned to Singapore to find the player is not sending a signal to either my TV (720p Pioneer PDP-436 XDE... I know!) or my computer screen and I suspect it has set itself up for 4K output based on the first TV it connected to.
Has anyone else come across this? I've searched online and found there is a Factory Reset procedure which says to:
① While the unit is on Press and hold [EJECT] on the main unit and the [0] on the remote control at the same time for more than 5 seconds.– POWER LED starts to flash, and “00 RET” is displayed on the screen.
② Press [>] (right) repeatedly on the remote control until “08 FIN” is displayed on the screen.
③ Press and hold [OK] for more than 5 seconds.
The trouble is this a procedure assumes there is a video signal being sent to the panel to be able to see "00RET" & "08FIN".
Thanks in advance!
Thanks in advance!
