Passive soundbar
Woody5
Hello, can anyone recommend a good passive soundbar to pair with my 65” C9 tv.
I was originally gonna buy a complete separate 5.1.2 setup but I don’t have the space distance for the RCL speakers as they have to go underneath the tv. I would like to mount it inside a recess so the slimmer the better if it’s possible.
my budget is small and can’t go above £1,000.
thank you.
keithwiggins
Look at the Goldenear supercinema x , I paid 1k for mine a few years ago quick look online shows you can get one for around £600 which is wild value, The unit really does sound far larger than wjat you would expect, mate it with a good sub, such as BK and you will have an amazing sounding system. Tons of great reviews online , it really is the dogs!
jmacc
Where do you see them for 600 mate?
LG CX 4K OLED TV Review: The best TV of 2020?
