Xexets
Established Member
Hi! I am looking to upgrade my TV and would like to get a 4K 55 inch one. Budget about £500.
I selected the two models above. The Philips one seems to review rather better than the LG in terms of picture quality, and has Dolby Vision (more future proof?) but Philips has a much worse reputation than LG for QC, warranty and support.
What would you choose? Or which other model would you suggest?
Main use: watching films (Netflix, Prime, ITunes/Google Play, Blu Ray), light gaming (PS4).
I will not connect the TV tuner at all, I never watch live TV.
No need for any smart feature. I have an Nvidia shield as main hub, might consider an Apple TV in the future.
No need for many connections Nor good audio, I have a Marantz 1506 that deals with multiple connections and audio.
Basically I just need a good 55 inch 4K panel with one HDMI port, possibly with as many HDR formats as possible (for future proofing)!
Thanks!
Thanks!
