U can try mine aboveHello
I know this is an old thread, but does anyone have any reasonable hdr settings for this phillips 7303. I know someone has a baseline
Thank you for the reply. Do you have idea on calibrating HDR I'm a complete noob. Are HDR and SDR the same settings. Or do I need to apply different brightness, contrast and colour settings. I'm in over my head with this TV. I have quite and old HDR TV Phillips 7303 which doesn't have any local dimming and only has a peak brightness apparently of 350 nits.U can try mine above
350 nits peak brightness. But it says HDR plus which I thought was 600.On this TV what is the hdr nit peak brightness
Would also like to know colour hue and saturation because this is really close to being a perfect picture apart from the reds.Hi RudeDog, Only had my 65" for about a week now and your settings have made a great improvement to the picture, but my Reds don't look really deep Red but more of a Pink/Magenta ish colour if you get my drift, would you know how to improve this.
TIA
I think HDR i also recommend the same settings.Thank you for the reply. Do you have idea on calibrating HDR I'm a complete noob. Are HDR and SDR the same settings. Or do I need to apply different brightness, contrast and colour settings. I'm in over my head with this TV. I have quite and old HDR TV Phillips 7303 which doesn't have any local dimming and only has a peak brightness apparently of 350 nits.
Try leaving them untouched. Red magentaHi RudeDog, Only had my 65" for about a week now and your settings have made a great improvement to the picture, but my Reds don't look really deep Red but more of a Pink/Magenta ish colour if you get my drift, would you know how to improve this.
TIA
Hi,Hello everyone, I am owner of a 58PUS7505 model and unfortunately I am having the exact same image quality issues. And it was through Google search that I found this discussion thread very informative.
Thanks to those who shared their settings, this has allowed me to improve the image quality.
For those who are interested, I also used the settings offered on this site:
La meilleure qualité d'image pour votre téléviseur
www.test-achats.be
Settings are not bad but still, it is not yet satisfactory.
The main problem is that the black areas are horrible (just like the captures shared in this thread).
Even on some bright scenes, the problem appears in the hair of the characters on the screen.
I managed to reduce the problem by setting the GAMMA to +4.
Another problem, depending on the shots, there is this washed-out effect on some shots without me being able to explain it.
Since the last exchanges, has any of you found a miracle solution ?
Thanks!
When you say you're getting 200 nits what window % size are you measuring? 1% 5% 10% etc?Unless I have messed up something, this TV is not having a wide gamut;
While on HDR mode or monitor 8 bit mode I get the sRGB gamut measurements.
I can barely get a white point close to 200 nits, I hardly imagine this TV could push 300 nits with its dynamic contrast or whatever (saying this because 42.5" Philips 43PUS7303/12 - Specifications claims that this unite has a 350 peak brightness) ... so I wouldn't really call this TV HDR.
I am measuring a small white square in the middle of the screen while trying my best to reach max brightness with all the settings.When you say you're getting 200 nits what window % size are you measuring? 1% 5% 10% etc?
And how are you measuring the colour measurements?
Does 30 brightness not crush blacks?I think HDR i also recommend the same settings.
For my tv model 8215 maybe different from yours. But the trick here is this
Switch to night isf.
Color 55 to 60
Backlight contrast 75 to 85
Brightness 30
Dynamic contrast minimum
Motion smooth
All Color hue or tint 0
Color control like red blue green yellow magenta ect +3 to everything
Color temperature normal
Color enhancement on or off
HDR upscaling off
Gamma +4
Video contrast 100
artifact and noise reduction to maximum
The above settings works best for both night and day View attachment 1694175View attachment 1694176
Not really. At 35 I can see enough details. But at brightness 50.it starts to Introduce grey into the pictureDoes 30 brightness not crush blacks?
I have to admit this tv now looks stunning. I have tested the sdr image out on Microsoft flight simulator on a Xbox series X. Yet to try HDR presets but will report back. Thank you for your help.Not really. At 35 I can see enough details. But at brightness 50.it starts to Introduce grey into the picture
I beleive even some.of the the Phillips presets use values.below 50.
Mine is put8215 . 2020 model. I agree for led tv it's actually quite good. I have calibrated to almost oled settings. Of cos it's not oled but close.I have to admit this tv now looks stunning. I have tested the sdr image out on Microsoft flight simulator on a Xbox series X. Yet to try HDR presets but will report back. Thank you for your help.
PS: The only problem with the HDR presets on this model 43pus7303/12 is that I can't alter Gamma. It's greyed out on every preset at 0.
I have another set of calibration if u interested : i actually found out that the brightness on my tv model 8215 is causing problems as it introduces grey into the picture. I think some displays like my ipad doesn't have a brightness setting , only backlight adjustment so i try to replicate that So i turned it off to zero and played with other settings. So far the details aren't lost in my new set of valuesI have to admit this tv now looks stunning. I have tested the sdr image out on Microsoft flight simulator on a Xbox series X. Yet to try HDR presets but will report back. Thank you for your help.
Yes but except in a dark room. But again it's still ledThis tv has a black crush unfortunately there is nothing that can be done about that. But your settings do improve the overall picture and looks very close to an oled.
Do you happen to do any gaming on your tv? Or is it for normal tv/movie viewing? Reason I ask is that I have an Xbox series X which I use for Flight simulator and a few more games. And your setting have hugely improved the picture at an expense of black digital levels dissapearing in game. I currently use your first recomendation of 30 brightness.Yes but except in a dark room. But again it's still led
