Hey sounds11 tried your settings & it has sorted the green issue I made some slight changes then but they are spot on
You talked about locking them down how do I do that ?
Cheers Sean
The 75PUS6754 is back on for £899 at Curry’s if anyone’s interested.
Televisions - Cheap Television Deals | Currys
Take advantage of amazing deals on our Televisions range here at Currys. Shop online and get free delivery or order & collect in store.www.currys.co.uk
It’s likely that Richer Sounds or John Lewis would price match that if you’re quick.
RS reduced their price to £899 this morning, and using TV20 discount code it can be had for £879.
I got mine from RS for that price. I paid an extra £20 for Saturday delivery. I think thats the best deal for this TV
Im thinking of returning my tv, for a LG 65sk8100 at the same price, but the again its smaler. I this a bad trade?
I live in Denmark, så pricing is not the same, but this lg will set me back 580£, and the philips 70pus6724 was the same 580, and I can get a 55 inch Oled lg B9 for around 780.It looks like a better overall TV according to this review.
LG 49SK8100 Ultra HD TV mit HDR10 und Dolby Vision im Test - Produkttest24.com - aktuelle Fernseher im Praxistest
LG 49SK8100 Ultra HD TV mit HDR10 und Dolby Vision im Test Der LG 49SK8100 im Test. Die neuen LG Super UHD Fernseher der SK8100 Modellreihe zeichnen sich durch das…www.produkttest24.com
However if you dont mind dropping to 55" size you can get the OLED Philips 55OLED754 with Ambilight for £1100 in the UK. If you're not worried about Ambilight Im sure I saw a 55" Hiesense OLED for £999 recently. Im sure the actual panels are probably from LG anyway.
Personally after a few years of my QLED Im a bit over the ultra picture settings when most of what i watch looks perfectly good on my much cheaper PUS6754.
Hi all loving my settings but I find in some dark scenes I get a blocky uneven look to the dark background of the image . Dose anyone know what setting I can adjust to sort ? Or is this normal on led IPS panels ?
It only happens occasionally but it's really annoying .
Cheers sean
Its due to bad compression or low resolution on the source material, you can set mpeg noise reduction and noise reduction hugger, helped for me on dvd's. I also get it alot on HBO nordic, due to a very low bitrate.Hi all loving my settings but I find in some dark scenes I get a blocky uneven look to the dark background of the image . Dose anyone know what setting I can adjust to sort ? Or is this normal on led IPS panels ?
Cheers sean
Its due to bad compression on the source material, you can set mpeg noise reduction and noise reduction hugger, helped for me on dvd's. I also get it alot on HBO nordic, due to a very low bitrate.
Btw my tv, was ok when I got to the dealer it had absolutely no bleed, and now the bleed is completely gone
I repaired tv for a multi brand workshops, and normaly on bigger tvs, the panel is a little loose, and can under the assembly be placed a little wrong. But mine under the transport placed right, and before I drove it had bleed, and after the drove it was ok.I've been buying Apple iPads since they launched. These displays are glued to the units. The glue takes days to set and is usually not fully bonded to the body when theyre shipped and delivered. People complain about light bleed and stupidly return unit after unit. However days later the glue sets sold and the light bleed is gone.
Have you decided to keep it? LCDs always have light bleed but mine is neglible to a point where its non-existant in my regular vewing even in the dark.I repaired tv for a multi brand workshops, and normaly on bigger tvs, the panel is a little loose, and can under the assembly be placed a little wrong. But mine under the transport placed right, and before I drove it had bleed, and after the drove it was ok.View attachment 1261623
Yes I will keep it, it has nearly no bleed now. It's a best case led tv now, so Im kind of impressed by it now.Have you decided to keep it? LCDs always have light bleed but mine is neglible to a point where its non-existant in my regular vewing even in the dark.
Yes
And it is a VA panel on my 70 inch, there is a color degradation at the sides. But it has crisp and nice Black instead though, so thats what Im after.
It looks Nice, with the extra hue lights.My IPS blacks are more than acceptible. In fact I think my 3yrs old QLED has started to develop light bleed and is worse. I think the incredible local dimining which hides this.
I love Ambilight. There are my Philips Hue Play bars behing the TV. Over 1,000 lumens of brightness on top of Ambilight.
Right now Im watching Rambo Last blood in 4K on my 75PUS6754 IPS screen with Philips Hue Play lamps and I could not be happier.
The extended lights look incredible and fill my whole flat with a jaw dropping ambience. My backwall is easily 200 inches in diamater and as you can see from the images and video the whole wll is bathed in light.
I cant help with that, as I dont use the casting, if I cast I use my built in chromecast in my mi box sHow well/smoothly do you find that casting to this TV works?
Screen mirroring works fine, but I find that casting from my phone (Android) using apps like LocalCast etc is a bit hit and miss.
For example, some videos play/forward/rewind with no issues, using either my phone or the TV remote to control. However, some videos play but won't forward/rewind... and some videos just won't play at all.
All of these videos play/forward/rewind on my other TV perfectly.
Thats an ok price, but I dont understand the pricing for the 70 inch in Denmark, as its 580£, and the 65 is also 580£, but the 75 896£, I think its quite a jump in price.
Its Calles 70pus6724, it was a marked New on philips webpage a week ago.I think your 70PUS6754 might be exclusive to Denmark. I have seen nothing else about it anywhere. Even Google only about seven results show up.
