Philips 7603 and HDMI Natural Motion problem
Stile
Hello,
did you notice the following "problem": when playing HD material from the PC (.mkv files) via HDMI on Philips 7603 HDMI in, Natural Motion option doesn't work if input on the TV is dedicated as HDMI -> PC.
If HDMI -> BlueRay is dedicated, then .mkv files playes correctly with working Natural Motion option. Any idea? Is it normal or fail?
Thank you.
peahead
Its normal most of the tvs processing is turned of when using pc mode can you not just change it from HDMI -> PC to something else.
chicote69
In the 9x03 series, is the same. To work HDMI -> PC, to see films HDMI -> Bluray
Stile
When I am watching movies, I put HDMI -> BlueRay but I had to be sure that this is not malfunction that this option doesn't work on HDMI -> PC mode.
Thanks. :thumbsup:
Similar threads
