Dalibor Koplik
Established Member
Any experiences with the new update? Does it make sense to install it?
I get Atmos sound through netflix and sound no problemDo I understand it right that it is not possible to stream Dolby Atmos from internal Netflix app to the soundbar through HDMI? I was going to order this TV together with Samsung HW-Q90R soundbar ....
There is a new software
TPM196E_091.003.051.081– Date: 2020/06/08
- Fix for Finland HbbTV services
- Fix for Network connection via LAN
- Some minor improvements
Has anyone tried this ?
How to make downgrade to one of the old software files (software updates history attached) if something goes wrong?
Has anybody problems with black screen which turns on for 1-2 seconds and than everything returns back to normal again?
It's happends when I'm watching satellites channels from enigma2 box (only use this connection).
Thanks in advance.
Yes, me too - already bought the TV and the soundbar couple of weeks ago. Netflix Premium subscribtion tested yesterday.I get Atmos sound through netflix and sound no problem
Why not to connect the satelite cable to the TV directly? Is the card paired with the box?had this problem seem with my engima2 box (what one you have btw) my box was stuck on 2160p30 I changed it by turning on unsupported resolution setting then changing to 2160p 50hz
I have a problem with my box taking control on my Philips remote do you know how to stop this I turn off control TV remote in E2 HDMI CEC settings but has not worked
Yes it paired with boxWhy not to connect the satelite cable to the TV directly? Is the card paired with the box?
I'm having a similar problem - If I turn on the TV with my Sky Q remote via CEC then ARC doesn't active and so the sound comes out of my TV speakers rather than my soundbar. However if I turn on the TV first using the TV remote the soundbar connects via ARC just fine. If I accidentally use the Sky remote then the only way to reset the TV and reactivate ARC is to fully unplug the TV and start again. I'm hoping a fix will eventually come from Philips!
In past I made some communication with them through official support which can be found on their website.How do I report a issue to Philips to hope get a fix in firmware
Did you get this sorted? Watching wall-e in Disney plus and the banding is horrendous, almost as though it's intentional.Installed the update, going to have to restore TV to factory settings as iPlayer won’t load again!
Also still getting terrible banding / crawling moire patterns (mainly in lighter colours) when the Apple TV is set to Dolby Vision. Bladerunner 2049, the smoke / steam where he lands the spinner at the farm in the beginning is a mess.
I’m seeing it in other things on Netflix and even in Disney + to.
I’m also experiencing this issue. Watching a show on Netflix on Apple TV shows terrible colour banding but watching the same show on the native Netflix app is totally fine. Also tried with Amazon Fire stick and same issuesDid you get this sorted? Watching wall-e in Disney plus and the banding is horrendous, almost as though it's intentional.
I'm also using firestick, only getting 8 bit from Disney plus but I didn't think about it being related to dv, I'll have a play about, thanks for the info.Interesting that you get it with Firestick, that suggests something not talking correctly on HDMI ports.
Have you gone in to settings and switched HDMI to enhanced?
I’ve messed around with the settings and it’s exactly the same.
I wonder if it has anything to do with this
It seems that there was an issue caused by Dolby that has now been fixed but requires the tv manufacturers to update the firmware.
I would hope but whether it is this issue or something else, there is definitely an issue with this tv and how it handles Dolby Vision content through HDMI. Which is a massive shame as the Dolby Vision content I’ve watched looks incredible! So I’m hoping it is something that can be fixed through an update.That link is from January 2018, I'd hope that particular issue has been dealt with by now.
Oh I agree there is, but like sue Hall pointed out there is a downgrade when Dolby Vision is applied via hdmi, in Disney plus if you were to watch something that's standard HD or hdr10 you'll get 12 bit through hdmi, but as soon as dv is applied you get 8 bit, and it seems that's the issue with banding, for whatever reason the tv won't accept Dolby Vision at 10 or 12 bit. The fact apple tv and firestick are both doing this points more towards the tv.I would hope but whether it is this issue or something else, there is definitely an issue with this tv and how it handles Dolby Vision content through HDMI. Which is a massive shame as the Dolby Vision content I’ve watched looks incredible! So I’m hoping it is something that can be fixed through an update.
