D
Deleted member 507786
Hi people, I have got the Pioneer vsx-lx70 amp stuck in stereo mode can someone help me get back to master audio? Thanks.
Thanks - I will give it a shot.Leaving the unit switched on disconnect the power chord. Leave off for a minute and replace the power chord. It may work, no guarantee.
Ah yes, that would be auto on a Denon. Thought you had gone past that stage. Anyway, glad it's sorted.Worked it out mate you have to put the amp remote in standard setting. Phew! Cheers for the help.
