For anyone thats gone from the last gen of panny plasma to a recent oled, how's the experience been? Obviously 4k and hdr has been a massive jump but how about motion, brightness and SD/HD content? How did you find the transition?
Afternoon,
I’ve just moved from a 65’’ ZD9 FALD LED to a 65C8 OLED, but previously had Pioneer Kuro Plasma’s including a KRP600.
Each of these tech’s have their pro’s and Con’s.
From a motion perspective, the OLED does display what I would describe as ‘micro-stutter’ when panning, but after a week I’ve adjusted to it.
The Motion on the ZD9 is, in my opinion, smoother than the OLED and on a par with the Kuro Plasmas.
I would describe myself as being ‘sensitive’ to motion issues, but the Micro-stutter I see on the OLED isn’t all the time. More importantly though, after a week I don’t really see it unless I specifically look for it.... so I‘ve stopped looking for it!!!
With respect to brightness, the 65C8 is significantly brighter/better than the Kuro’s, but the ZD9 is better again In this respect. Having said that, HDR is stunning on both the C8 and the ZD9... and your plasma can‘t do HDR!
In think you’d be very happy with a move from plasma to OLED if you can adjust to it’s drawbacks. If not, consider a good FALD LED set which can be a very good compromise.
