Vic 0681
Hi All,
wanted to get some help please on the positioning of my rear speakers on a 5.1 setup in the living room of an open plan layout.
I have the ceiling wall mounts, but am struggling on where to position them in my new open plan extension which is currently under construction.
option 1: position them on the two side pillars either side of the rear sofa. However if the sofa is moved 30cm further back then the rears are on the side/slightly in front of the listening position.
option 2: I place the rears right at the back, behind the dining table and above the bifold doors. Floor distance is approx 3 metres behind the rear sofa. I am not sure if this would be too far for rear speakers and whether they would bleed too much and therefore not get the impact when sitting on the sofas?
Attached is the layout.
thanks
thanks
