apoorvasheth
Hello All,
I have Sony PS3, Sony 65X8500D 4K HDR TV, Harman Kardon HKTS 9 5.1 Home Theatre & Yamaha Amplifier RX-V685.
- PS3 is connected to the Yamaha Amplifier in one of the 5 HDMI Inputs via an HDMI cable.
- Another HDMI cable is connected from the HDMI Out of Yamaha amplifier to the HDMI 2 IN of the SONY TV.
When I turned On the PS3, the green power light appears however, I do not see the boot screen. On my Yamaha Amplifier remote, I selected the HDMI Input to which PS3 is connected into. The TV screen now switches between 480p and some other resolution (I guess 1080p) which keeps flashing at the top corner BUT, it doesn't show the PS3 welcome screen.
This PS3 used to work last before I wrapped it & kept aside as I didn't have much games to play. This is almost 4 years ago after which the PS3 was wrapped. I have now removed it from the soft cardboard to use it & above is the issue that I am facing presently.
- I also have a small 32inch LG LCD TV in my bedroom to which I directly connected this PS3 via an HDMI cable. On this screen as well, nothing appears.
What could be the issue? Is it with the HDMI port of the PS3? HDMI cable cannot be the issue as its a working HDMI cable & I tried 2 different HDMI cables in this process but to no avail. How to fix this issue than? Will it land into the Sony Service Centre for repairs or any "Home Remedies" can work out? This is Out of warranty.
Kindly reply asap...
