Kieran30
I have a 65b8pla purchased from Currys. Is this tv future proof for the ps5. Should I be happy with it? I could have got a 8K Qled for a bit more money but there wasn't any in stock at the time.
Yeah all this talk is just that. Making sure the "other side" paps themselves.The graphics power needed to run modern games at 8K is insane and I highly doubt the PS5 will be able to render at that resolution natively.
I'm sure the B8 will be absolutely fine for the PS5 where 4K will be the more common resolution it will run at.
I've got B8 awesome tv hopefully the new consoles will look great on itB8/C8 is already amazing for PS4 gaming so it's only going to be better for PS5! I've played all these years without VRR so I'm sure I will be just fine playing on PS5 without.
2018 OLED's are a bargain right now imo.
The new consoles will be backwards compatible with any tv that has an HDMI port. The 2.1 standard allows 4K120Hz at 4:4:4 gaming should the consoles support it - and until recenlty, the indication has been that it may be a struggle - although Sony seem confident they can support it in the PS5. Moreover, there is no known plan for any game on these consoles to run at those specs. The only gaming units arguably able to handle those specs will be PCs with the newest Nvidia cards.Guys is there someone reading these posts please as im bit concerned that i bought a new tv this year lg oled b8 and its got hdmi 2.0 will the new consoles work if there 2.1 hdmi
Ok thank you so basically will be getting the same we got now but just not the 2.1 features were i think its mainly for pc vrr could be ok for consoles so were get the same as we get now but slightly better as the console got better chipset etc and being more powerful just without 2.1 features were i dont think it matters much to consoles is this right buddy many thanksThe new consoles will be backwards compatible with any tv that has an HDMI port. The 2.1 standard allows 4K120Hz at 4:4:4 gaming should the consoles support it - and until recenlty, the indication has been that it may be a struggle - although Sony seem confident they can support it in the PS5. Moreover, there is no known plan for any game on these consoles to run at those specs. The only gaming units arguably able to handle those specs will be PCs with the newest Nvidia cards.
It's not something to worry about. Your B8 will work absolutely fine, and you won't be missing out on much at all by not having a 2.1 enabled TV for the forseeable future.
No. I believe their max frate rate for true 4K to be ~30 fps. To achieve 60 fps they probably upscale 1440p to 4K.Do you guys really think the new ps5 and xbox scarlett will run games at a steady 4k 120hz?
