Quantcast
Question Q Acoustics 3070s
Meyrick Man
Can the above sub be laid on its side to use? I haven't got the room to stand it up. Thanks in advance
Conrad.
IN theory, yes. However, if you put it in too small of a space you'll effectively be changing the port dimensions. Does it have much room behind it and to the sides?
Meyrick Man
At the back but not the sides
Conrad.
Ok, as long as the back opens into space, and presumably the front opens into the room, then you should be fine. If you have a photo of the proposed location that would help.
Meyrick Man
Thanks I'll post a pic
Meyrick Man
Meyrick Man
Similar threads
