Finally took the plunge and got a 65 q85.
Just a quick question..
Getting no signal on Freesat. I know the cable and dish are 100% (tested on another set - works fine).
Are the default settings good "as is" or do I have to modify something in the satellite section? I've only done a auto scan.
Probably something simple I'm missing.
Thanks.
Thanks.
