Kazman
- Joined
- Jan 14, 2004
- Messages
- 5,361
- Reaction score
- 145
- Points
- 901
- Age
- 48
- Location
- Luton, Bedfordshire
xbox 360, PC or both?
Kazman said:xbox 360, PC or both?
harrisuk said:Neither I thought it was pants on the P.C. Really the Quake series has gone done hil rapidly since Quake 2 which was the absolute nuts
Kazman said:My PC Spec is a Athlon 64 (Venice core) 3.2
6600GT PCI-E (single right now, might get a second for SLi next month)
1GB Ram
Should be beefy enough for Q4 I reckon?
Razor said:6600gt is an ok card but I dont think it will be powerfull enough to run Quake 4 on full settings. Maybe look to the xbox version and if you dont like it take it back for another game.
True, but why would you, especially for a FPS.pez said:but then you can get joypads for the pc if you want them.
pez
1GB RamQUOTE]
Can i recommend a bit of caution when upgrading to an SLi setup. I'd wait til its more stable. I have one and to stop quake 4 crashing to desktop i had to disable the 2nd graphics card!!!
hillster said:Apparently it's also got Quake2 on the disc, not sure if this is true though.
tino05 said:you guys are reallllly depressing me - I bought it today & was mega looking forward to it.
I cracked doom 3 relatively quickly as well
Razor said:If you liked Doom3 then you should like this. Its very similar to Doom except it isnt as dark and depressing. Quake 4 grows on you as you progress through the game. Towards the end it is all out big weapon time which is most fun, no saving your rockets for the end guy. You will be using all your powerfull weapons. I would give it a 9/10 but thats me, some members are not as impressed as I am.
