RECOMMENDED 4K & 3D COMPATIBLE MOTORISED PROJECTOR SCREEN
swerve147
Hi Guys
as the title suggests can anyone recommend a electric ceiling mounted projector screen for 4K and 3D projector?
Im looking at a 120inch screen...some ive seen are way too expensive..Im looking at around £400 price tag
thanks guys
noob0101
Hi Guys
thanks guys
There are no 3D compatible screens. A wall is a 3D compatible surface. Unless it's passive. But I'm not going to into it since it's unlikely you have such a setup.
In this price range of projector you should not worry about 4K compatibility.
swerve147
Hi noob0101 so are you saying any projector screen is fine for 3D ...how about 4k..Ive a budget of £400 for a projector screen thats good with 3D and 4K..just need a recommendation
