rampant
- Joined
- Apr 24, 2006
- Messages
- 2,702
- Reaction score
- 1,260
- Points
- 707
- Location
- Sarf est near londoninium
Hi all,
I am waiting for delivery of my new Dell T7920 (2 * Silver 4214 CPU's / 128GB memory / 2 * 1TB SSD's). It has a 1300w power supply and i can use up to 4 GFX cards at a time. It doesn't come with a GFX card, and was wondering if you can give me any recommendations.
My machine is primarily used for SQL / OLAP / Machine learning / AI together with virtual machines for testing / developing software.
I also like to play some games. I have output to 2 monitors at 1080p - not 4k yet
I will be running Windows 10 on the machine as the primary OS together with VMWorkstation (my other server runs my HyperV VM's)
What would be a good graphics card to use? Ideally i want to have a GPU that's modern and would match in processing terms with the new CPU's (to reduce any potential bottlenecks) - In my current machine (Dell T5600) i have a 1050ti 4gb memory GFX card.
I'm looking at maybe the following price ranges:
sub 100
100-200
200-300.
would consider using 2 - so probably 600 max budget for both.
Regards
sub 100
100-200
200-300.
Regards
