Recording from Freeview Tuner on LG65C9
El Barto
How useful is it?
looking to ditch VM TV and use the TV or am I better just buying a BT Box for recording TV?
can you record to a HDD on your server or does it have to plugged directly into the TV?
mikej
I've had a couple of TVs now that allowed direct HDD recording, but I've always preferred using a PVR. I can't speak for the C9 specifically but, in general, I think you're always going to get more functionality from a dedicated PVR than recording directly to a HDD from a TV.
Probably the most important aspect is the ability to record one channel while watching another - a simple task for any PVR but not for a TV, unless it has dual Freeview tuners. I've had a PVR in the past that actually allowed you to record two channels while watching a third.
grahamlthompson
also i don't think tv's allow series link
If the TV is a genuine Freesat one. Series link is built in to the freesat epg. However most TV's only have a single tuner. Some allow one tuner to make 2 recordings at the same time from a single transponder. eg Simultaneous recordings from BBC1-HD and BBC-2-HD are possible. An example is a single tuner Humax HB-1000S can do this.
grahamlthompson
How useful is it?
It has to be plugged directly into the TV, and it gets formatted in a file system no other kit can read. Do not think you can unplug the drive and watch the files on anything else. There is however lots of kit that can record to a standard file system and use the recordings elsewhere.
Similar threads
The Best Movies and TV Shows Coming To Netflix in October 2020. Tom's Thumbs.
