Smoke me a Kipper
Amazon have got the First five red dwarf series for release on blu ray on the 15th of august
Yes they're releasing the US Paul MaGann Dr Who tv movie. This was shot on film so would benefit from a blu release if the original film material was available. I understand this is not the case and it would need work similar to the Star Trek TNG releases. I think this is unlikely and it'll also be an upscale.
Bri
That one is also a bit of a mystery but at least a true HD release isn't impossible, Red Dwarf just doesn't have the source material available so expect nothing more than the masters they created for the DVDs stuck on BD with a better bitrate and perhaps lossless audio.
Of course if they go and change the framerate to 24p and/or smother the image in DNR they really will be a disaster.
So you think they maybe SD transfers with a higher bit rate rather than an upscale? The possibility of this used to get talked about but hasn't been done to the best of my knowledge.
Bri
No I meant they took the masters they created for the DVD's and upscaled them.
As for putting 576p SD material on Blu-ray it's quite popular in Germany with shows like Buck Rogers and Ren & Stimpy among the releases.
Ah yes I seem to recall hearing of some SD releases abroad but I didn't know they were NTSC.
Bri
Of course.NTSC is 480p, the German releases are 576p which is PAL.
