benzi
Established Member
Hi All,
My current 5.2 setup for my lounge/cinema room (4.8m x 4.8m x 3.0m ceiling height) is as follows:
My main use is now very much movies (75% movies/25% music) thus I was looking at adding a bigger sub(s) to the room to improve the bass for movies. Initial thoughts were to add a HT1205/HT1508 to supplement the Rel T5s but reading through numerous threads on here...I'm now stuck.
Should I keep the Rel T5s and add a bigger sub to the setup?
Should I replace the Rels with something more HT orientated?
Given the size of the room, would I be ok with one sub? I know the Rel T5s are little and sound much better as a pair.
Options considered:
From a bass management point of view, initially I'm going to use the Yamaha but I'm considering adding a Lyngdorf 1120 to my system...2.2 setup for music and use it in HT theatre mode when watching movies...
Any help/advice would be appreciated .
Kind regards,
Benzi
- M&K Sound MP950 L/C/R
- M&K Sound M40T as rears
- 2 x Rel T5 setup as stereo pair with Neutrik and LFE cables simultaneously. I listen to music in "Pure Direct" thus like the Neutrik connection to supplement music
- Yamaha RX-A 3070
Options considered:
- Rel HT1205 or HT1508
- M&K Sound V12
- SVS SB2000 / SVS SB3000
Kind regards,
Benzi
