San5324
Established Member
Is there a "hearable" difference between lossy and lossles ATMOS? My Philips OLED754 does not have eARC as well, but from USB drive can send DV to the screen and Atmos (not lossles, I think) to the soundbar. I would need to buy a UHD player with two HDMI outputs.
There is no way you can not here the difference between lossless and lossy. It would be the same as comparing 4k TV with HD ready.
It doesn't matter if u don't have earc. If you directly connect your bluray with the bar you also have lossless. There is actually no other way, unless you have earc. Even then, you still won't get the 48gb with most tvs that got an update to earc. Most tvs with an update get around 42gb
