D
Deleted member 433786
Ahh i see mate, my bad, My set also states the mode when i select ok on the remote (providing the remote isn't paired to the device) i guess it will only show HDR on the KS sets if you do this? As you say it will be showing everything correctly, would be nice if it would say so, if only to show people who don't believe that it is capable. The differences you will have noticed will be correct, compromises have been made with HLG to enable the SDR and HDR stream to be included in the same single transmission and maintain backwards compatibility with SDR only sets
cheers
cheers
